Seeing the app map services from outside the network
655
09-04-2012 10:26 PM
JudyTroutwine
Map services in my VS 2010 Silverlight application work fine when launched from within VS2010, and the map services can be seen in the ArcGIS Services Directory with the JavaScript viewing option with the full URL (e.g., the URL appropriate from outside the network).
After publishing to IIS, the app also works well with "localhost" in the URL.  However, when specifying the full URL, the map services do not display.  I did a comparison with a simple app with one layer -- same problem.  I have checked permissions in IIS.
What could be the issue here?
