Return feature.shape from server by using WCF and ArcGIS Silverlight API
848
01-27-2013 01:05 AM
MohamedOthman1
I am using arcgis silverlight api
I all i need to do is to get geometry from feature by objectid to zoom to it
getFeature(objectid);
so i used WCF service to get the geometry but i found error that say
Type 'System.__ComObject' cannot be serialized
can you help quickly please
Thank you in advance
MohamedOthman1
eventually I found a solution
using Query Task and pass in the where clause the filter like
query.where="objectid=17";
but when i need to save edit delete in sde use WCF service
that's set
MohamedOthman1
that's set
