how to zoom to feature by objectID in arcgis silverlight api programmatically?
2158
01-27-2013 02:41 AM
MohamedOthman1
hi there,
I want to zoom to feature by objectid in arcgis silverlight web application
i want to get feature by object id first then zoom to the geometry of the feature
help me please
SanajyJadhav
You can the query the layer using where clause - "OBJECTD = " + OID_Value;setting return geometry to true. IF the query is successful, you would get the geometry of the selected feature in the query execute completed event back. Then, you can use this geometry to zoom to.
HTH.
SanajyJadhav
HTH.
MohamedOthman1
thank you very much i found a solution yesterday night it's the same idea
you are so kind
eventually I found a solution
using Query Task and pass in the where clause the filter like
query.where="objectid=17";
but when i need to save edit delete in sde use WCF service
that's set
