Questions regarding ESRI applications
1126
05-06-2011 04:29 AM
PaulHuppé
When you create a new ESRI Standard or Showcase Map Application, you get a folder in your solution called "Themes", in which there is a file called "generic.xaml".  This file loads resource dictionaries.  What I would like to know, is how is this file used/called because there is no reference to it anywhere I can find?
Also, these applications use a namespace as follows:
xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp"
How can I had this namespace to my application which I did not create from the 2 templates mentioned above?  When I try to add a namespace, it does not show up as a choice.
Paul
DominiqueBroux
Esri Frequent Contributor
The default templates of the custom controls have to be defined in the Themes/generic.xaml file.
This file is automatically used by Silverlight, you don't have to reference it in your project.
PaulHuppé
Thanks for the clarifications. I give this a try.
Paul
