Access to Graphics collection on FeatureLayer
1523
04-24-2011 11:28 PM
juliangarcia-anton
In a project using ESRI Silverlight api version 1.2, I was able to add a FeatureLayer to my map, (the layer resides in ArcGIS Server 9.3.1) and could access the Graphics Collection to interact with the features on the layer.
I have updated the project to use the ESRI Silverlight api version 2.1, in order to use some new funtionality, but now I find that the Graphis Collection is empty and I cannot find a way to access the features on the layer.
Is this a new limitation imposed by the new api, or is there a different way to access features on a FeatureLayer ? Would upgrading to ArcGIS Server 10 solver the issue ?
Thanks.
DominiqueBroux
Esri Frequent Contributor
I don't see any limitation imposed by the new API which could explain your issue.
Check that your service is avilable and that you can get the features using the REST API (something like http://serverapps.esri.com/ArcGIS/rest/services/California/MapServer/0/query?text=&geometry=&geometr...).
Then if you service is working, you will need fiddler to figure out the issue.
juliangarcia-anton
Thanks for your reply Dominique,
I did finally solve the issue, by accessing the features at the UpdateCompleted event, instead, of the Initialized event for the FeatureLayer.  So I do think that there is a slight difference because with the 1.2 DLL the graphics collection at the Initialized event was full, and in version 2, it is empty.
Thanks again.
j.
dotMorten_esri
Esri Notable Contributor
I can confirm that this is a slight change of behavior between 1.x and 2.x.
