QUery Failed:
988
08-29-2013 12:11 PM
JeffFrye
I am using a queryTask with ZoomTo off of an EXECUTE Button. When I first click the button, I receive the ERROR CODE 400: Unable to complete operation. If I click OK then click EXECUTE again, the query is fine and the point displays and zooms accordingly.
// Draw results when query is complete.
        private void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            // Clear previous results.
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            // Check for new results.
            FeatureSet featureSet = args.FeatureSet;
            if (featureSet.Features.Count > 0)
                // Add results to the map.
                foreach (Graphic resultFeature in featureSet.Features)
                    resultFeature.Symbol = LayoutRoot.Resources["ResultsMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.SimpleMarkerSymbol;
                    graphicsLayer.Graphics.Add(resultFeature);
                    MapPoint communityPoint = graphicsLayer.Graphics[0].Geometry as MapPoint;
                    ESRI.ArcGIS.Client.Geometry.Envelope e = new ESRI.ArcGIS.Client.Geometry.Envelope(
                        communityPoint.X - 1000,
                        communityPoint.Y - 1000,
                        communityPoint.X + 1000,
                        communityPoint.Y + 1000);
                    MyMap.ZoomTo(e);
            else
                MessageBox.Show("No features found");
LanceCrumbliss
I think this is actually a bug in the version of ArcGIS Server you are querying.
Add a string to the end of your query like "1=1", but make it dynamic so it isn't cached.:
Dim q As New Query() Dim dirty As String = Date.Now.Ticks.ToString q.Where = String.Format("{0}={1} AND {2}={2}", "FID", "10", dirty)
LanceCrumbliss
