Problem with the Silverlight Find task
3089
11
11-03-2010 01:42 AM
JacobSaugmann
I've followed the instuctions from this : http://help.arcgis.com/en/webapi/silverlight/2.1/help/Find_task.htm
But every time i clik the Find button i get this error:
Find error: ESRI.ArcGIS.Client.Tasks.ServiceException: Object not set to an instance of an object.
my c# code from the click event:
findTask = new FindTask("REMOVED HERE But Valid url used");
            findTask.ExecuteCompleted += new EventHandler<FindEventArgs>(findTask_ExecuteCompleted);
            findTask.Failed += new EventHandler<TaskFailedEventArgs>(findTask_Failed);
            FindParameters findParameters = new FindParameters();
            findParameters.LayerIds.AddRange(new int[] { 6, 8 }); //layer id for vejnavne
            findParameters.SearchFields.AddRange(new string[] { "VEJNAVN" });
            findParameters.ReturnGeometry = true;
            findParameters.SearchText = autoCompleteAdresse.Text.ToUpper();
            //debug data
            MyTextBlock.Text = findParameters.SearchFields[0].ToString() + " " + findParameters.SearchText + " " + findParameters.LayerIds.ToString() + findTask.Url;
            findTask.ExecuteAsync(findParameters);
Any idea whats is Wrong?
DominiqueBroux
Esri Frequent Contributor
A first glance your code looks good.
I suggest that:
1) you verify that your service is working well by testing the 'Find' url : <mapServiceUrl>/Find
Example of Url with ArcGISServiceOnLine : http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...
2) use fiddler to look at the requests sent by your silverlight application. Hopefully this will give a clue.
MatthewCarey
Maybe you just slipped up in your cutting and pasting, but shouldn't the first line read:
FindTask findTask = new FindTask("REMOVED HERE But Valid url used");
Just in case.....
TomJohnson
I'm having the same problem.  If I access the "find tool" directly from the REST url, it almost works.  The result information I get is:
# results: 1
59957S44858
    Feature ID: -1
    Field Name: Grid Number
    Layer: Pole
It doesn't return a proper Feature ID, any of the attributes, or the geometry (even though it was requested.)
Next, if I add "&f=json" to the end of the request to get a JSON response, the response I get is:
{"error":{"code":500,"message":"Object reference not set to an instance of an object.","details":[]}}.
There definitely seems to be something wrong on the server side here.  Has anybody been able to resolve this issue?  For some reason everything works on the ESRI sample map services.
JenniferNery
When you perform Find from your web browser, do you use the same parameters that your application use? Can you verify that these parameters are correct and both app and browser yield to same result? Please refer to post#14 from this thread to guide you on what to look for when running Fiddler with your app http://forums.arcgis.com/threads/14730-Area-And-Perimeter
Appending "&f=json" to the Url should not have caused this error. I tried the same here: http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...
EugeneChuguy
Hi, a have a same problem. When i set the Direct Connect in project and restart service the Silverlight App send request like this
.../Find?searchText=11086&contains=true&returnGeometry=true&searchFields=OBJECTID&layers=1&f=json&
and i have an error
But when i try to send the request without parameter f=json i get expected result. Where is the solve?
JenniferNery
Have you tried creating the web request from your web browser? Error 500 is from the Service?
It's hard to suggest a fix. I don't understand the problem. Does it work if you don't append "&f=json"?
JacobSaugmann
Im still struggling with this problem, i get Object not set to instance of an object, or Error 500, the string looks ok(i use Firebug in Firefox)
this is the url
https://gis.verdo.dk/ArcGIS/rest/services/GRUNDKORT/GrundkortRDS/MapServer//Find?searchText=B%C3%B8sbrovej&contains=true&returnGeometry=true&searchFields=VEJNAVN&layers=8&f=json&
When i remove f=json&
the server returns 379 results all with the feature id = -1
Any idea??
AliMirzabeigi
If you are using ArcGIS 9.3 please make sure you have installed the latest service packs. The reason I'm suggesting this is that it looks like if the rows returned from your request contain some special characters like quote, double quote, etc... the REST request fails to return the results. More information on this thread: http://forums.arcgis.com/threads/11834-Error-500-with-JSON-in-Find-operation
JacobSaugmann
YES YES YES YES 😄
An upgrade to sp2 solved my problem 🙂
THANKS
Merry Christmas
