Path and names of tool images in Editor Widget?
1023
06-21-2012 11:34 AM
DanielSchatt
hi, I'm trying to build a Help window describing the Editor Widget tools and, within that help, I'd like to show the small images within those tools.  So I need the path and the names of those images to use as the sources in the image tags.  Is there some place that I can access to see the images and get that information?  Thanks!
Dan
JoeHershman
The toolkit source code can be downloaded from Codeplex, so you can do that and see what the paths to the images are.
-Joe
JoeHershman
-Joe
DanielSchatt
Thanks much!   Actually I had downloaded the Silverlight Toolkit already. For anyone else who needs to do this, the project in there (ESRI_Silverlight_Toolkit) contains all the code.
