Problem with reprojection
2599
04-27-2012 12:22 PM
by Anonymous User
Not applicable
Original User: rogeryc
Hi, I'm having the following issue:
[ATTACH=CONFIG]13896[/ATTACH]
The yellow flag is a point feature with WGS 84 zone 20S projection (wkid: 32720), in a feature layer. Using Bing or ArcGIS Online map, that point is correctly drawn by the viewer. The green star is a graphic added to a graphic layer in the same projection (32720) with the same x,y coordinate.
Why are they drawn in different places?
Regards,
Roger.
DeminHu
How you add that green point,  can you show your code here?
by Anonymous User
Not applicable
Original User: jenniferdnery
Does your GraphicsLayer Graphic.Geometry has its SpatialReference set?
by Anonymous User
Not applicable
This is the code:
var point = results[0].Geometry as MapPoint;
GraphicsLayer graphicsLayer;
Layer layer = Mapa.Layers["X,Y Point"];
bool isNull = (layer != null);
bool isGraphicLayer = (layer is GraphicsLayer);
if (isNull && isGraphicLayer)
    graphicsLayer = layer as GraphicsLayer;
else
    graphicsLayer = new GraphicsLayer();
    graphicsLayer.ID = "X,Y Point";
    graphicsLayer.SetValue(MapApplication.LayerNameProperty, nombreCapaGrafica);
graphicsLayer.ClearGraphics();
graphicsLayer.Graphics.Add(results[0]);
if (MapApplication.Current.Map.Layers[graphicsLayer.ID] == null)
    MapApplication.Current.Map.Layers.Add(graphicsLayer);
Regards.
by Anonymous User
Not applicable
No, the spatial reference is null, and I don't know how to set it, because the SpatialReference property is read only. What am I missing?
Regards.
