Problems binding URL
838
05-01-2012 04:59 AM
KåreRasmussen
Hi everybody.
I´ve downloaded the "FrostedTabs" Silverlight example and Im trying to set the URL thru binding:
<esri:ArcGISDynamicMapServiceLayer  ID="Aflob" Initialized="ArcGISTiledMapServiceLayer_Initialized"
                                                           Url="{Binding Path=SetupModel.LayersUrl}" />
The SetupModel is init thru the main method of the silverlight app:
        public MainPage()
            InitializeComponent();
            MainPageViewModel mainPageViewModel = new MainPageViewModel(); //Here the SetupModel property is initialized
            LayoutRoot.DataContext = mainPageViewModel;
The LayersUrl property looks like this
        private SetupModel setupModel;
        public SetupModel SetupModel
            get
                if (setupModel == null)
                    setupModel = new SetupModel();
                    setupModel.LayersUrl = "http://localhost/ArcGIS/rest/services/aflob/MapServer";
                    setupModel.OverViewMapUrl= "http://localhost/ArcGIS/rest/services/aflob/MapServer";
                    OnPropertyChanged("SetupModel");
                return setupModel;
            set
                if(setupModel!=value)
                    setupModel = value;
But when the page is loaded, an error like this occurs:
SCRIPT5022: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.ArgumentNullException: 'Url' is not set.
Parameternavn: Url
   på ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e)
   på ESRI.ArcGIS.Client.Layer.Initialize()
   på ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer.Initialize()
   på ESRI.ArcGIS.Client.Map.OnApplyTemplate()
   på System.Windows.FrameworkElement.OnApplyTemplate(IntPtr nativeTarget)
If I replace the Binding with this:
                                                           Url="http://localhost/ArcGIS/rest/services/aflob/MapServer" />
Everything works great.
Why is that?
Any suggestions/comments are greatly appreciated
/Kaare
JenniferNery
dotMorten_esri
Esri Notable Contributor
Unfortunately because 'Layer' is not a FrameworkElement, it doesn't have a DataContext, and therefore Binding wouldn't work.
If you have your datacontext defined in your viewmodel which is exposed as a static resource, you can however bind to static resources.
ex: Url="{Binding Source={StaticResource myViewModel}, Path=MyLayerVM.Url}"
