Problem with FeatureLayer
1827
9
04-12-2011 11:14 AM
DonFreeman
Can someone tell me why this layer
<esri:ArcGISDynamicMapServiceLayer ID="City_Intersections"
       DisableClientCaching="False"
       Url="http://gismaps.pagnet.org/ArcGIS/rest/services/ARRA_033011_2_plot/MapServer"
      VisibleLayers="1"
will render OK as a DynamicMapServiceLayer but will not render as a FeatureLayer?
Thanks
MattMiley
The featurelayer link needs too look like this
Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/1"
Not this way
Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer/1"
DonFreeman
Not this way
Hi Matt. Did you try it?
 <esri:FeatureLayer ID="County_Intersections"
       Url="http://gismaps.pagnet.org/ArcGIS/rest/services/ARRA_033011_2_plot/FeatureServer/4"
       OutFields="*"
Doesn't work yet load it as a MapService and it works fine.
DominiqueBroux
Esri Frequent Contributor
The shape fields containing the geometry are hidden by your services, hence the rest end points are not returning any geometry.
You have to update your service (check the visible fields with ArcGIS desktop).
Note : ArcGIS server 10 may be more strict than previous version concerning this point.
DonFreeman
If we unhide the shape fields, is there a way to hide them when we identify?
DonFreeman
Dominique -
We have unhidden ALL of the fields in the service layer but it still does not load as a FeatureLayer. CAn you see a specific field that is missing?
       Url="http://gismaps.pagnet.org/ArcGIS/rest/services/ARRA/FeatureServer/4"
       OutFields="*"
DominiqueBroux
DonFreeman
http://gismaps.pagnet.org/ArcGIS/rest/services/ARRA/FeatureServer/4 returns Invalid URL
Sorry about that. It moves around a bit. Try this:
       OutFields="*"
ChristopherHill
If you look at the link here you will see that there is no (feature server)
you need to see ARRA_033011_2_plot(Feature Server) in order to have a url ending with /FeatureServer
You can use your MapServer in a FeatureLayer as ready only and you need to append the sub layer to the end.
<esri:FeatureLayer Url="http://gismaps.pagnet.org/ArcGIS/rest/services/ARRA_033011_2_plot/MapServer/1" />
DonFreeman
Problem solved. Thanks Chris. ACtually, this puts me back to where I was originally with the xaml. Check the second post to see where I was advised differently. The problem originally seems to be that the shape layer(s) was turned off.
Thanks
