Graphics layer - Change color on graphic mouse over
1231
04-12-2011 01:26 PM
BrentStevener
I have a graphics layer of features that I draw, with associated symbols. How can I change the color of each graphic on the graphics layer when you mouse over it? I am adding these manually in code-behind applying a symbol to each feature from a featureclass I created from a JSON string. Is there some way to attach a mouse over method at the time I create the graphic? Some other way?
BrentStevener
Been a long day. All I needed was to use Addhandler to the graphic I was creating, for the MouseEnter event. *sigh* Issue resolved.
dotMorten_esri
Esri Notable Contributor
You should be using SymbolStates for this instead of changing the Symbol back and forth.
Some of the symbols in this sample has various mouseover behaviors defined:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomSymbols
BrentStevener
That's what I ended up doing after I was having problems with the events not firing correctly, and that is working fine.
