Print task and Graphics layer issue (PLS READ THIS POST)
3464
10-09-2013 02:25 AM
by Anonymous User
Not applicable
Original User: gporta
Hi to all,
i have the following situation: i would like to save with printing tool the image of map ( image inside pdf ) with on the map a feature layer and e graphic layer.
the feature layer is defined in this way:
            <esri:FeatureLayer ID="Province" Url="http://myserver/arcgis/rest/services/MyLayer/MapServer/0
                               Renderer="{StaticResource MySymbolRenderer}" Where="OBJECTID=1">
            </esri:FeatureLayer>
and
<esri:SimpleRenderer x:Key="MySymbolRenderer">
                <esri:SimpleRenderer.Symbol>
                    <esri:SimpleFillSymbol Fill="Beige" BorderBrush="Red" BorderThickness="1"/>
                </esri:SimpleRenderer.Symbol>
            </esri:SimpleRenderer>
And that all ok , now in the behind code i would like to add a graphic layer in this way:
Transfer the just only one selected object from feature layer to graphic layer
    private void button1_Click(object sender, RoutedEventArgs e)
            GraphicsLayer gl = new GraphicsLayer();
            gl.ID = "MyGraphicsLayer";
            FeatureLayer f = MyMap.Layers["Province"] as FeatureLayer;
            gl.Renderer = f.Renderer;
            for (int k=0; k<f.Graphics.Count;k++)
                Graphic g = new Graphic();
                g.Geometry = f.Graphics.Geometry;
                gl.Graphics.Add(g);
            MyMap.Layers.Add(gl);
All works good , but if after this , use the print tool ( export image on pdf ) i have inside the legend instead of the name of Graphic layer (MyGraphicsLayer) on the map i have a long number....... see attached files.
It's a bug certainly .... is there a qorkaround or patch to solve this ? Im using silverlight api 3.1 and ags 10.2.
if i set
g.Symbol = LayoutRoot.Resources["PolygonSymbol"] as SimpleFillSymbol;
with
<esri:SimpleFillSymbol x:Key="PolygonSymbol" Fill="Yellow" BorderBrush="Yellow" BorderThickness="0"/>
i have an overryde inside the legend ... see capture2.png on attach
if i don't se any symbol i have black layer on map and black layer on pdf legend but the correct name of layer ... see capture3.png on attach
Thanks for reading and maybe answering
GP
brettangel
Try this:
            gl.SetValue(MapApplication.LayerNameProperty, "MyGraphicsLayer");
            gl.GetValue(MapApplication.LayerNameProperty);
brettangel
Try this:
