Pan To A Selected Graphic
979
05-06-2010 02:05 PM
KevinKingrey
I need to pan the map using VB to a point selected in a graphics layer named "Results".  I have not been successful in finding an example to use.  Does anyone have some examples I could referr to?  I know this should be pretty simple, but I'm not having any luck.
DominiqueBroux
Esri Frequent Contributor
If you want to pan to a graphic object of your graphics layer, you can directly call the PanTo method of the map:
graphic.Geometry.SpatialReference = MyMap.SpatialReference
MyMap.PanTo(graphic.Geometry)
/Dominique
