Override Mouse Hover on Navigation Control
1024
10-24-2012 07:07 AM
MarkLawrence
I am using the ArcGIS 3.0 SDK for Silverlight.  I would like to override the mouse hover scale transform, and leave the control permanently maximized.
However, I am limited because I do not have access to Expression Blend.
Is there a way to override the content template for the scale transform without overriding the entire control's template in Visual Studio?
DominiqueBroux
Esri Frequent Contributor
No you have to override the entire template.
Without Blend, you can get the default navigation Template from the toolkit sources on codeplex, copy it in your project and modify it for your need.
DominiqueBroux
MarkLawrence
Hey, this worked great, learned a lot today :).
