New user, Few questions :)
886
03-25-2011 01:46 AM
AshleyEtherington
Hey all I saw the library's here and thought they would make a much better suite for what I am doing over deep zoom/other mapping api's. I have a few questions tho
  • Am I able to use my own map image? Eg I have 24 images that consist of a map
  • Is it possible for me to generate my own cordinats , E.g top left corner = xy0 and bottom right = 15000
  • Can I dynamically add content via a database (Using WFC services ofc)
  • If the first two are possible is there any "beginner" documentation, So far I can only find the forums and the documentation on the library.
I put them in order of importance, Thank you for reading!
JenniferNery
You can use ArcGISImageServiceLayer http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ArcGISImag...
Sure, you can convert these screen coordinates to map coordinates: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#MouseCoords
Here's a blog post on sending geometry back and forth with WCF: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/03/11/Sending-geometry-between-Silverlig...
Please visit Concepts page: http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Getting_Started/016600000004000000/
Interactive SDK samples: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm
