can you control grids in silverlight?
1506
03-18-2011 10:04 AM
JimHenry
Is there a grids feature that I can get access to either in xaml or c#?  I could do this with features but I would like to dynamically change the spacing without having to generate/swap features.
[ATTACH]5457[/ATTACH]
JimHenry
In case other are looking for an easy way to create a grid this link did help:
http://mappingcenter.esri.com/index.cfm?fa=ask.answers&q=223
But I would still like to create/modify a grid on the fly with a web app.
JimHenry
I was not thinking that the coordinate system that I was using would lay an evenly spaced grid but it does so I was able you use the following solution:
            List<ESRI.ArcGIS.Client.Geometry.Polyline> polylineList = new List<ESRI.ArcGIS.Client.Geometry.Polyline>();
            for (int lat = -90; lat <= 90; lat += 10)
                ESRI.ArcGIS.Client.Geometry.PointCollection pointCollection = new ESRI.ArcGIS.Client.Geometry.PointCollection();
                pointCollection.Add(new MapPoint(-180, lat));
                pointCollection.Add(new MapPoint(180, lat));
                ESRI.ArcGIS.Client.Geometry.Polyline polyline = new ESRI.ArcGIS.Client.Geometry.Polyline();
                polyline.Paths.Add(pointCollection);
                polylineList.Add(polyline);
            for (int lon = -180; lon <= 180; lon += 10)
                pointCollection.Add(new MapPoint(lon, -90));
                pointCollection.Add(new MapPoint(lon, 90));
            GraphicsLayer graphicsLayer = Map.Layers["GridLines"] as GraphicsLayer;
            foreach (ESRI.ArcGIS.Client.Geometry.Polyline polyline in polylineList)
                Graphic graphic = new Graphic()
                    Symbol = LayoutRoot.Resources["DefaultLineSymbol"] as Symbol,
                    Geometry = polyline
                graphicsLayer.Graphics.Add(graphic);
