Need develop some custom tools such as zoom in , out ...
4922
16
06-09-2015 07:13 AM
LucianaArrúa
I need to develop some custom tools on map..such as zoom in, zoom out, filters and many more.
I need to develop this in silverlight .
I don't know where to start from.
How to proceed?
Currently I have VS 2010
Need Help!!
RebeccaStrauch__GISP
LucianaArrúa
thanks for your materials!!!
ChrisSergent
I created a .NET application against the JavaScript API and created custom tools. You can check out my code behind. Perhaps that will help: csergent45/SOA-Final · GitHub
I code in VB.NET so if you want or need to convert the code to C#, you can do it here: Convert C# to VB.NET - A free code conversion tool - developer Fusion
The good news is that if your are comfortable with Visual Studio, you can still develop in it in JavaScript. And there is a lot of support for it online and in the GeoNet forums to help you along the way.
LucianaArrúa
thanks for your input,!! but who add your code in Visual Studio and visualize the application?
Regards,
ChrisSergent
Are you new to Visual Studio? I can do a quick screen recording if you want to see how to run it using the JavaScript API.
LucianaArrúa
yes, I'm new in VS....
Please, thanks .... I need help about this ...
ChrisSergent
Here is a screen recording that I show you how to create a single page site in Visual Studio and then run a code example by Esri. You may want to turn the volume of your PC up while listening.
You can check out the Esri tutorial how to create the page in steps:
Build your first application | Guide | ArcGIS API for JavaScript
Also if you are going to the Esri User Conference, they are an introductory session to the JavaScript API, that you should find helpful; more than one if you need it to take it all in.
