Navigator Tool on ArcGIS API for Silverlight 3.0
3407
8
09-03-2012 05:19 AM
EzequiasRodrigues_da_Rocha
Hi everyone.
I would like to know if there is any component we can use to simulate the basic navigating tool (without using keyboard shotcuts).
Basically I would like to have the ZoomIn, ZoomOut, Pan, ZoonIn Center, ZoonOut Center as shown in the image below.
[ATTACH=CONFIG]17445[/ATTACH]
Thank you in advance.
Sincerely
Ezequias R. da Rocha
Based in the suggestion from dlimos above I did implement zoomIn and zoomOut tools but unfortunately they can't work togeather.
Can anyone help me with this issue?
When I leave just one in my AddIns project the tool works great but when there are two it does not.
Here is my AddIns project: https://www.box.com/s/9x1j7x7filtpfmfmakzr
Regards
Ezequias
I got the solution by myself. The solution is avaliable on: https://www.box.com/s/qz11g3yno1qyf0znlfps
Thank you all!
Ezequias
DavideLimosani
I think it is an old version of ArcGIS API for Silverlight (2.4*). Don't you think so?
Even though it looks like my desire I actually want to add this feature on ToolPanel 3.0.
Thank you
Ezequias
DavideLimosani
I know that in 3.0 that sample is missing, but I don't see any reason why it should not work.
Am I missing somtehing?
No, I agree with you but I still do not know how.
Sincerely
Ezequias
DominiqueBroux
Esri Frequent Contributor
The toolbar control has been removeed from version 3.0.
You can still start with the 2.4 sample but we have to replace the toolbar control with your own control (that might be as simple as a StackPanel with Buttons inside).
The handlers behind the buttons should still work.
maybe this sample?
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ToolBarWidget
Regards
Ezequias
Regards
Ezequias
Thank you all!
Ezequias
BrianHjort_Nielsen
I have the same problem, why has it been removed? The handler behind don't work, or i just dont know how to get it to work...
