MouseLeftButtonDown Event at Runtime
1448
04-14-2011 11:02 AM
AgatinoLa_Rosa
I have a GraphicsLayer managed at runtime, it is not coded in xaml. I have tried to add a click event
in the InitializeComponent() section of the cs for this layer:
myGraphicsLayer.MouseLeftButtonDown +=new GraphicsLayer.MouseButtonEventHandler(myGraphicsLayer_MouseLeftButtonDown);
and I get of delegate error. Any suggestion?
DominiqueBroux
Esri Frequent Contributor
Difficult to guess anything without seeing the handler.
AgatinoLa_Rosa
I am not sure if I follow you. Do you mean for handler:
private void myGraphicsLayer_MouseLeftButtonDown(object sender, MouseButtonEventHandler args)
            ///zoom to selected graphic
DominiqueBroux
The second argument of your handler should be of type GraphicMouseButtonEventArgs
private void myGraphicsLayer_MouseLeftButtonDown(object sender, GraphicMouseButtonEventArgs args)
This has been changed a few time ago, hence the confusion.
AgatinoLa_Rosa
Ouch!! Thanks. It works.
