Maptip binding issues (creating maptips on graphics layers programmatically)
2216
12-09-2010 07:23 AM
AlexZlotin
I am programmatically adding graphics layers to a map and assigning maptips to these layers. I am running into a problem with binding, as the field values do not get displayed in the maptips.
Thanks in advance for any insights.
Alex
private void DisplayLayerMaptips(FeatureSet featureSet, FeatureLayerConfig featureLayerConfig)
    //Locate graphics layer by name
    string maptipGraphicsLayerId = "Maptip_" + featureLayerConfig.Id.ToString();
    GraphicsLayer graphicsLayerMaptip = (GraphicsLayer)MainMap.Layers[maptipGraphicsLayerId];
      //If graphics layer is not present in the map, create it and assign maptip
      if (graphicsLayerMaptip == null)
        StackPanel maptipPanel = new StackPanel() { Orientation = Orientation.Vertical };
         //Add field names and values (as bindings) to maptip
        foreach (FieldConfig fieldConfig in featureLayerConfig.MaptipFields)
            StackPanel fieldPanel = new StackPanel() { Orientation = Orientation.Horizontal };
            TextBlock fieldNameText = new TextBlock() { Text = featureSet.FieldAliases[fieldConfig.Name]};
            TextBlock fieldValueText = new TextBlock();
            Binding binding = new Binding(fieldConfig.Name);
            fieldValueText.SetBinding(TextBlock.TextProperty, binding);
            fieldPanel.Children.Add(fieldNameText);
            fieldPanel.Children.Add(fieldValueText);
            maptipPanel.Children.Add(fieldPanel);
        graphicsLayerMaptip = new GraphicsLayer() { ID = maptipGraphicsLayerId };
        graphicsLayerMaptip.MapTip = maptipPanel;
        MainMap.Layers.Add(graphicsLayerMaptip);
      else
        graphicsLayerMaptip.ClearGraphics();
      //Add features to the graphics layer
      foreach (Graphic feature in featureSet.Features)
        feature.Symbol = CreateSymbolForMaptip(feature.Geometry);
        graphicsLayerMaptip.Graphics.Add(feature);
AlexZlotin
Found the answer myself... The names of the fields to be bound need to be surrounded by square brackets.
Binding binding = new Binding("[" + fieldConfig.Name + "]");
