Is there any SL control that acts like floating panel?
1962
6
07-16-2010 08:31 AM
BinBin
I need to popup an window after click a button, not chilewindow, and I want to place some controls in this window that can interact with my map.
Any ideas?
Thanks
PaulLeedham
I am curious to why you would not want to use a child window, this is an out-of-the-box control that acts like a floating panel.  If you do not want to use the child window option you will need to create your own control or use a third party solution.
Paul Leedham
City of Hudson
http://gis.hudson.oh.us/
BinBin
Because child window blocks interaction with the parent window.
Where can I get the out-of-box-control you mentioned?
Thank you
Paul Leedham
City of Hudson
NateArnold
Looks like Tim Heuer's FloatableWindow (refactored ChildWindow) might work for this...
http://timheuer.com/blog/archive/2009/05/10/silverlight-childwindow-non-modal-refactor.aspx
BinBin
Thank you, but it is for SL 3
Is there anything for SL4?
JoshWerts
The simplest solution is to add a window that's visibility is collapsed initially.  Just add a button that changes its visibility property to visible when you need it to "pop up".
MyWindow.Visibility = Visibility.Visible;
Look at ESRI's DraggableWindow control in the showcase map template - control it with its "isOpen" property (which just controls its visibility)
Josh
Clemson University
PaulLeedham
We use custom controls that function similar to a floating panel.  We acquired our controls from a 3rd party--WebGIS-Solutions.  They have a couple of different storyboards you can select to use when the pop-up window opens.  If you look at the measure or bookmark tools you can see how they operate.  Example: http://gis.hudson.oh.us/WorkOrders/
I have also used the pop-up control from Telerik.
Paul Leedham
