DynamicLayer + VisibleLayers property
1170
07-14-2010 10:23 PM
BrianBorg
I am setting the VisibleLayers property in xaml
VisibleLayers="2,7,12"
and I am getting this error:
Error 1 Unable to cast object of type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentPrimitiveNode' to type 'Microsoft.Expression.DesignModel.DocumentModel.DocumentCompositeNode'.
DominiqueBroux
Esri Frequent Contributor
If you get this error in Blend only, it looks like the same issue than
http://forums.arcgis.com/threads/3676-Error-message-explanation-needed
RobertBurke
Brian,
Even though you see the error can you still test Run the app?  I had the same thing and my app still ran. In the end I moved the VisibleLayers property setting from XAML into C#.
Rob Burke
Esri Redlands - Instructor
Rob Burke
BrianBorg
I had to remove it from xaml and put it in c#.
I am not using blend but VS2010
dotMorten_esri
Esri Notable Contributor
Unfortunately this is a bug in VS2010 (it used to be there in Blend 4 as well, but got fixed after we reported it - unfortunately didn't make it for VS2010). You code will still compile and run though.
