How to set Opacity of TocLayer
1235
12-13-2011 10:24 PM
SelçukTınaz
Hi Everyone,
  I have a problem about setting opacity of TocLayer. I have seven MapService those are already loaded, I am selecting one of these MapServices and then selecting one of its Layer(TocLayer).
I need to set this ones opacity, but it looks like it is LayerInfo and it doesn't have "Opacity" property.
Any Help?
Thanks in Advance
ChrisBradberry
You have to set the opacity to the whole map service, you can't single out sublayers in the service and change the opacity.  I have not had much luck in setting the opacity in the mxd before I make the service either.
Chris
JenniferNery
You can turn the sub layer off by excluding its ID in ArcGISDynamicMapServiceLayer.VisibleLayers property and create a FeatureLayer for this sub layer instead so you can control its Opacity.
SelçukTınaz
Thanks for all your answers,
But, I don't want to add any additional Layer, because I have much already, when I add one more, the application getting worse. Because of this, I need to use SubLayers(they are typeof LayerInfo) inside the ArcGISDynamicMapServiceLayer without adding any.
Thanks for All
