Web Editing - FeatureClass with Relationship
870
07-24-2011 06:49 PM
YamunadeviRathinasamy
I am doing web editing in silverlight(REST-FeatureService). I have a featureclass and related to a table by one-many.
How to create, Edit, Delete feature with relationship?
JenniferNery
You can edit the feature service and table by representing each as FeatureLayer. You can also query their relationship similar to this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryRelatedRecords. The FeatureLayer that represents your table, need to be initialized and then updated, so you may perform your edit on its rows.
by Anonymous User
Not applicable
I am correct to assume that currently editing of related tables is NOT support through the ESRI REST api (irrespective of API) - correct?
JenniferNery
You can edit related table using FeatureLayer. It would be same as FeatureLayer from a feature service, only table consists of features with only attributes (no geometry).
by Anonymous User
Not applicable
Hi Jennifer,
Just to be clear (apologise i need to find time to prototype this but if your able to clarify for now i would appreciate).  Are you inferring the related table can be edited in isolation or as part of a related record associated with an feature (e.g. select a feature & then able to edit its related records) & if so is this supported with the edit widgets or only through customisation?
Brad
