How to set Image Sevice Layer Symbology
3707
01-13-2011 05:35 AM
by Anonymous User
Not applicable
Original User: a5xs
I am using a mosaic object to store time tagged images.  I discovered that if I create a mxd and publish to a dynamic map service my symbology changes do not get saved to the service and there is no way to get access to the values.  Therefore I switched to an image service in hopes that I would have access to the values.  In the arcmap gui I see I have access to the symbology properties but now I need access to them via code.
Hooks I am looking for are:
1. Turn on alpha channel
2. Set alpha channel to band 4
3. Set the stretch type to none
[ATTACH]4257[/ATTACH]
[ATTACH]4256[/ATTACH]
JimHenry
Thanks to Laurence from ESRI support for help so far!
I am still in search of code hooks on the image service to turn on the alpha channel set it to band 4 and set the stretch type to none?
[ATTACH]4679[/ATTACH]
Good - I took the raw data and through code generated an image.
Better - Through a script take out the alpha channel.
Best - The original smoothed image.
[ATTACH]4681[/ATTACH]
[ATTACH]4680[/ATTACH]
by Anonymous User
Not applicable
Original User: chri6255
Hi Jim,
Here is an example of the syntax you would you for a rendering rule performing a "Streach" raster funtion. There is a link below of different ways you can use the render rule to manipulate your image service.
RestLayerProperties();
imgLayer.BandIds = new int[] {0,1,2,3};
IDictionary<string, object> functionArguments = new Dictionary<string, object>();
functionArguments.Add("StretchType", iStretchType);
functionArguments.Add("NumberOfStandardDeviations", numberOfStandardDeviations);
functionArguments.Add("Statistics", statistics);
functionArguments.Add("Gamma", gamma);
imgLayer.RenderingRule = new RenderingRule()
RasterFunctionName = "Stretch",
RasterFunctionArguments = functionArguments,
VariableName = "Raster"
imgLayer.Refresh();
Here is a link to the documentation on what types of rendering rules you can use against your image service.
http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/israsterfunctions.html
