How to use RenderingRule with Colormap to display imagery in greyscale
1094
02-10-2011 09:27 AM
BobbyRadakovich
I am trying to apply a RenderingRule using a Colormap to switch my imagery display from color to greyscale (print preview for people without color printers).  Here is my code snippet from the button handler that handles the switch:
[INDENT]        private void Button1_Click(object sender, RoutedEventArgs e)
[INDENT]            ArcGISImageServiceLayer lyr = (ArcGISImageServiceLayer)(MyMap.Layers[0]);
            RenderingRule rule = new RenderingRule();
            rule.VariableName = "Raster";
            rule.RasterFunctionName = "Colormap";
            Dictionary<string, object> parms = new Dictionary<string, object>();
            parms.Add("ColormapName", "Gray");
            lyr.RenderingRule = rule;
            lyr.Refresh();
[/INDENT]        }
[/INDENT]
The code runs fine, but when the imagery layer refreshes instead of displaying in greyscale it just disappears altogether.
Ideas?
DominiqueBroux
Esri Frequent Contributor
Your dictionary of parameters looks initialized but never used.
ChristopherHill
// Make sure when you are applying rendering rule that you are only
// using a single color band id. Layer may have multiple color bands.
// You have to select a single color band id to convert to grayscale.
lry.BandIds = new int[] { bandID };
rule.RasterFunctionArguments = parms; // Missing this line
lyr.Refresh();
