How to restrict identify layers
11088
32
03-10-2011 08:20 AM
DonFreeman
Is there a way to restrict the layers that are returned with an identify query?
  private void QueryPoint_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e)
   ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
   ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
    Geometry = clickPoint,
    MapExtent = MyMap.Extent,
    Width = (int)MyMap.ActualWidth,
    Height = (int)MyMap.ActualHeight,
    LayerOption = LayerOption.visible,
    SpatialReference = MyMap.SpatialReference
   IdentifyTask identifyTask = new IdentifyTask("http://gismaps.pagnet.org/arcgis/rest/services/Interactive_TIP_2011/MapServer");
   identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
   identifyTask.ExecuteAsync(identifyParams);
   GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
   graphicsLayer.ClearGraphics();
   ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
    Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
   graphicsLayer.Graphics.Add(graphic);
I tried putting the layer numbers in the url but that did not work.
JenniferNery
You can refer to this link for IdentifyParameters http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Tasks.Iden...
You can set LayerIds property.
DonFreeman
Thanks Jenn. That is helpful.
DonFreeman
What is the syntax to set LayerIds? When I try LayerIds = [1,2] it tells me the property is readonly.
JenniferNery
Ah yes, this is read-only but you can add id's to it:
 identifyParams.LayerIds.AddRange(new int[] { 1, 2 });
DonFreeman
Thanks Jenn. This works. I don't understand how it can be readonly but you can still write to it, but as long as it works I'm happy.
Have a great weekend.
JenniferNery
Oh it is read-only in the sense that the instance cannot be changed but the collection can be modified. 🙂
//identifyParameters.LayerIds = new System.Collections.Generic.List<int>(); <-- cannot change instance
identifyParameters.LayerIds.AddRange(new int[] { 1, 2 }); // can change collection
You have a good weekend too.
BrandonCales
Is there a way to remove specific ones without list all of them except the specific ones...
e.g. RemoveRange (2, 4)...
DominiqueBroux
Esri Frequent Contributor
The REST API doesn't offer an option to exclude some sublayers.
You have to build by yourself a layerIds list with all values except the values to exclude.
DonFreeman
Build the list of layers you want to be included like this:
            List<int> LayerList = new List<int>();
            LayerList.Add(0);
            LayerList.Add(1);
            LayerList.Add(2);
            LayerList.Add(3);
                LayerOption = LayerOption.top,
            identifyParams.LayerIds.AddRange(new int[] { 4,5 }); // These are the layers you want included.
            IdentifyTask identifyTask = new IdentifyTask("http://gismaps.pagnet.org/arcgis/rest/services/ARRA_042211_plot/MapServer");
