How to restrict identify layers
11064
32
03-10-2011 08:20 AM
DonFreeman
Is there a way to restrict the layers that are returned with an identify query?
  private void QueryPoint_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e)
   ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
   ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
    Geometry = clickPoint,
    MapExtent = MyMap.Extent,
    Width = (int)MyMap.ActualWidth,
    Height = (int)MyMap.ActualHeight,
    LayerOption = LayerOption.visible,
    SpatialReference = MyMap.SpatialReference
   IdentifyTask identifyTask = new IdentifyTask("http://gismaps.pagnet.org/arcgis/rest/services/Interactive_TIP_2011/MapServer");
   identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
   identifyTask.ExecuteAsync(identifyParams);
   GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
   graphicsLayer.ClearGraphics();
   ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
    Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
   graphicsLayer.Graphics.Add(graphic);
I tried putting the layer numbers in the url but that did not work.
DominiqueBroux
Esri Frequent Contributor
AFAIK, the raster layers inside a map service are managed the same way than any feature layer.
How did you set the LayerOption and the LayerIds of your identify task?  If LayerOption is set to visible, it means that the identify is taking care of the scale and so will not identify the raster layers that are not visible at the current scale.
Could this be your case?
If your service is public, can you share the identify request that is sent to the service (use fiddler to get it)?
RamonLira
has four sets of layers and each group has thirteen layers. I want to identify the values �??�??of the thirteen layers depending on which group is active regardless of which only some are visible.
LayerOption is "all" and  identifyParams.LayerIds.AddRange(new int[] { 1,2,3,4,5,6,7,8,9,10,11,12,13 });
return value of layers 1 and 2
if modify:
identifyParams.LayerIds.AddRange(new int[] { 1,3,4,5,6,7,8,9,10,11,12,13 });
return value of layers 1 and 3
if modify:
identifyParams.LayerIds.AddRange(new int[] {10,11,13 });
return value of layers 10 and 11
RamonLira
and I do not know where it is used fiddler, sorry
RamonLira
Oh it is read-only in the sense that the instance cannot be changed but the collection can be modified. 🙂
//identifyParameters.LayerIds = new System.Collections.Generic.List<int>(); <-- cannot change instance
identifyParameters.LayerIds.AddRange(new int[] { 1, 2 }); // can change collection
You have a good weekend too.
help me please, i have problem with identify rasters layer, only return the value of first two layers,no matter how many layers I add
returned value of layers 1 and 2
if modify:
returned value of layers 1 and 3
DominiqueBroux
Is your service public and could you share the map service URL, so we could test our side?
RamonLira
this is my service:
http://sag01.iie.org.mx/ArcGISServer/rest/services/RecursoEolico/MapServer
DominiqueBroux
Hi Ramon,
I tested with your service and I am not able to reproduce the issue.
After setting the LayerOption to 'all' and the LayerIds to the range 1-13 (as you did), the identify task returns the infos about the 13 raster layers. See attached screenshot.
So for me, everything seems OK.
RamonLira
Hi Ramon,
Thank you, my code is wrong, I did with the example as you and  the query give me all values�??�??.
thank you very much dbroux
BrandonCales
Got it working....
The code below will identify only visible layers, whether they are a parent layer or feature layer within a group layer....
        public List<int> checkVisibility()
            List<int> visibleLayers = new List<int>();
            if (MapLegend.LayerItems != null)
               //look at feature layers in service layer [0]
               foreach (LayerItemViewModel enabledLyr in MapLegend.LayerItems[1].LayerItems) //Change this to [0], when MapLegend (xaml) specifies "LayerIDs="MainLayer"" -- [1] when not
                   //look and non-grouped feature layers
                   if (enabledLyr.LayerItems == null)
                       //is it visible
                       if (enabledLyr.IsVisible)
                           //exclude specific layers (before InitializeComponent) ==> List<int> ExcludeLayerList = new List<int> { 13, 14 };
                           if (!ExcludeLayerList.Contains(enabledLyr.SubLayerID))
                               visibleLayers.Add(enabledLyr.SubLayerID);
                   //look and grouped feature layers
                   if (enabledLyr.LayerItems != null)
                       //loop through feature layers under parent group
                       for (int i = 0; i < enabledLyr.LayerItems.Count; i++)
                           //is it visible
                           if (enabledLyr.LayerItems.IsVisible)
                               //exclude specific layers ==> List<int> ExcludeLayerList = new List<int> { 13, 14 };
                               if (!ExcludeLayerList.Contains(enabledLyr.LayerItems.SubLayerID))
                                   visibleLayers.Add(enabledLyr.LayerItems.SubLayerID);
           return visibleLayers;
BarraLoubna
I would like to specify the identify parameter to appear only the layers that are displayed in the list of layers, you can visualize my post here:
http://forums.arcgis.com/threads/71468-How-to-structure-the-Identify-tool-depending-on-the-visibilit...
Do you have any idea?
