How to make animated / moveable controls
1275
08-15-2010 07:49 PM
StephenLead
Honored Contributor
All of the samples at http://help.arcgis.com/en/webapi/silverlight/samples/start.htm use static controls. Eg, the TOC or overview map just sit there.
In the site at http://gis.cityofboston.gov/solarboston/ they have some nice animated controls, which the user can reposition as necessary. How do you achieve this?
I'm using Visual Studio 2010 with Silverlight 4. I have the Expression Blend 4 SDK but not Expression Blend 4.
Steve
TerryGiles
For an example of moveable controls, check out the 'unblended' application template available from ArcGIS.com - http://www.arcgis.com/home/item.html?id=b77d416635a74e66ab222fe519af2eb7
The Boston site was done in Flex, but I would think you could add some animation to the controls in SL as well.
PaulLeedham
Although it may take a little bit of time to learn, Expression Blend will provide you with the tools to build your own animations through building storyboards that can be executed through your UI.  If you do not have the time to build your own controls and animations, there are various third parties where you can purchase controls with pre-configured animations such as Telerik or ComponentOne.
StephenLead
Honored Contributor
Thanks for the tips, I'll give em a go.
