How to get the total number of vertex of FeatureLayer?
1589
09-01-2011 10:59 PM
zhouning
ESRI.ArcGIS.Client.FeatureLayer mFeatureLayer = new ESRI.ArcGIS.Client.FeatureLayer();
mFeatureLayer.Url = featureLayerUrl;
mFeatureLayer.MaxAllowableOffset=600;
MyMap.Layers.Add(mFeatureLayer);
Now I want to know how many vertex the Client side drawed when loaded the FeatureLayer.
The FeatureLayer is a polygon layer.
Because I want to know the effect of the property "maxableoffset".
YipeiCheng
I am interested in this topic too, anyone who can give an answer?
DeminHu
I wonder if you can wrap the plogon to pointcollection, the get the point count.
dotMorten_esri
Esri Notable Contributor
You should be able to do it uinsg a LINQ query. For example:
(from c in (from b in (from a in layer.Graphics select a.Geometry as Polygon) select b.Rings) select c.Count).Sum();
zhouning
Thanks your reply!
And I tried your suggestion, but the value of the variable 'VertexCount' didn't change when I changed the value of MaxAllowableOffset(Even set it as zero). The code as below:
  string featureLayerUrl = " http://server.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Average_Household_Size/MapServe...";
mFeatureLayer.MaxAllowableOffset=861;
mFeatureLayer.Initialized += new EventHandler<EventArgs>(StartTimer);
mFeatureLayer.UpdateCompleted += new EventHandler(FeatureLayer_UpdateCompleted);
   void FeatureLayer_UpdateCompleted(object sender, EventArgs e)
        { VertexCount = (from c in (from b in (from a in mFeatureLayer.Graphics select a.Geometry as ESRI.ArcGIS.Client.Geometry.Polygon) select b.Rings) select c.Count).Sum();
I think the value of the VertexCount is the sum of the plygon's rings ,and it is the initial value,not the optimized value.In the other words,it is on server-side ,not the cilent -side.
DominiqueBroux
Esri Frequent Contributor
The calculation is done at the client side. If you get the same result than at the server side, it means that your maxallowableoffset is not enough selective. Try with a higher value.
Note that the maxallowableoffset is a value given in map coordinates so the value is depending on your spatial reference and your map scale (e.g. a value that makes sense is 2*map.Resolution, it means that the distance between two vertices is at least 2 pixels).
