How to add a cancel button in FeatureDataForm?
1798
6
11-02-2010 06:48 AM
XiujuZhou
I need to add a button  in FeatureDataForm in order to cancel the graphic just added on graphic layer. Is that possible and how to add it in Expression Blend?
JenniferNery
Here's a blog on how you can customize the look and feel of ArcGIS controls http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/05/20/Use-control-templates-to-customize...
It's similar steps except you choose FeatureDataForm
XiujuZhou
Thanks Jennifer. I still cannot add a button to it. the FeatureDataForm is kind of one control, the Apply button cannot be seen,  and my button cannot be inserted into FeatureDataForm.
AliMirzabeigi
Look for the following section of FeatureDataForm default control template. I have added a "CancelButton" on the left side of "CommitButton", i.e.
<Button x:Name="CancelButton" Content="Cancel" Grid.Column="0" HorizontalAlignment="Right" HorizontalContentAlignment="Center" Margin="0,0,12,0" MinWidth="75" MinHeight="22" Style="{TemplateBinding CommitButtonStyle}" Visibility="Visible" VerticalAlignment="Center" VerticalContentAlignment="Center"/>
<Grid Height="166" Width="246">
<Grid.RowDefinitions>
<RowDefinition Height="*"/>
<RowDefinition Height="Auto"/>
</Grid.RowDefinitions>
<ScrollViewer Background="{x:Null}" IsTabStop="False" Padding="{TemplateBinding Padding}" Style="{StaticResource CustomScrollViewerStyle}" VerticalScrollBarVisibility="Auto">
<ContentPresenter x:Name="ContentPresenter" Margin="12,12,6,12"/>
</ScrollViewer>
<Grid Margin="0,8,0,8" Grid.Row="1">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="*"/>
</Grid.ColumnDefinitions>
<Button x:Name="CommitButton" Content="{TemplateBinding CommitButtonContent}" Grid.Column="1" HorizontalAlignment="Right" HorizontalContentAlignment="Center" Margin="0,0,12,0" MinWidth="75" MinHeight="22" Style="{TemplateBinding CommitButtonStyle}" Visibility="Collapsed" VerticalAlignment="Center" VerticalContentAlignment="Center"/>
</Grid>
</Grid>...
XiujuZhou
Thank you Ali. I am wondering why my xaml code of FeatureDataForm copied from Resource center is just black box:
   <esri:FeatureDataForm x:Name="MyFeatureDataForm"   FeatureLayer="{Binding Path=Layers[PointLayer], ElementName=MyMap}"  IsReadOnly="False" LabelPosition="Left" />
How can I convert the code to be style like yours? then I can add the button.
AliMirzabeigi
You can use Expression Blend and right-click on your FeatureDataForm and select "Edit Template" --> "Edit a copy...", then you will get the default control template for your FeatureDataForm. Switch to the XAML view and look for the "CommitButton" button. Jennifer shared a very good URL on how to do the styling in Blend, you can also look into that page.
XiujuZhou
Thank you very much, Ali! the way you provide is great! that is what I am looking for.
