Handle double click on graphics layer
1804
05-08-2012 08:55 AM
MarkCollins
I am looking for an event or some way to handle double click on a graphics layer or more specific on my features in a feature layer.
Any one done this before or have any ideas? I know this sounds super simple but I can not find an event handler for it....
Mark
dotMorten_esri
Esri Notable Contributor
If you are using Silverlight 5, you could also use the Map.MouseLeftButtonDown event and check the ClickCount property. Example:
   private void MyMap_MouseLeftButtonDown(object sender, System.Windows.Input.MouseButtonEventArgs e)  {   if (e.ClickCount == 2)   {    var graphicslayer = MyMap.Layers.OfType<GraphicsLayer>().First(); //Grab graphics layer    var graphics = graphicslayer.FindGraphicsInHostCoordinates(e.GetPosition(null)); //find any graphics over clickpoint    var topGraphic = graphics.FirstOrDefault(); //grab the first hit    if (topGraphic != null) //we hit a graphic    {     e.Handled = true; //prevent map from zooming     MessageBox.Show("You dbl clicked a graphic");    }   }  }
JenniferNery
You can do something like this. But you might also want to consider click tolerance besides checking for same graphic and elapsed time since last click.
    Graphic graphic;
    TimeSpan elapsedTime;
    DateTime? startTime;
    private void FeatureLayer_MouseLeftButtonDown(object sender, GraphicMouseButtonEventArgs e)
     if (graphic == null || graphic != e.Graphic)
      graphic = e.Graphic;
      startTime = DateTime.Now;
     else if (graphic == e.Graphic && startTime.HasValue)
      elapsedTime = DateTime.Now.Subtract(startTime.Value);
      if (elapsedTime.TotalMilliseconds < 500)
       //double click happened
      graphic = null;
      startTime = null;
dotMorten_esri
MarkCollins
Excellent, thank you both!
