Error
1022
05-08-2012 10:43 AM
RickWarner
I just finished a tutorial on creating my first application in silverlight using arconline services. I then tried to create the application in a new website and it stopped generating the following error. Why did I get this error?
If the cross domain worked for the tutorial, why not when applied to a new website?  Both are made on same developer machine, using aspnet development server.
  "Unhandled Error in Silverlight Application A security exception occured while trying to connect to the REST endpoint. Make sure you have a cross domain policy file available at the root for your server that allows for requests from this application.   at ESRI.ArcGIS.Client.Layer.OnInitializationFailed(EventArgs e)
   at ESRI.ArcGIS.Client.Layer.Initialize()
   at ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer.<>c__DisplayClass1a.<MapServiceInfoInitFailed>b__18()  eval code, line 1 character 1"
How do you add the cross domain policy file to the root to a deveoper server?
Thanks for any help.
ShreyasVakil
If you are using online services, then it should not ask you to add crossdomain.xml, because it is already there. You can check at http://services.arcgisonline.com/crossdomain.xml . Can you post some code or maybe the URL of the services you are accessing.
