Graphic tool - Draw Polygon Polygon disappears after finish drawing
3323
03-23-2011 12:44 PM
YingLin
I am using arcGIS silverlight api 2.1 SDK. Created a button for drawing polygon using ESRI:RedlineAction
<esri:RedlineAction
    Color="Red"
    DrawMode="Polygon"
    GraphicsLayerID="MyGraphicsLayer"
    TargetName="Map" />
when drawing is finished, the polygon disappears. I want it to stay so that it can be used when creating printouts. Drawing with polyline and freehand functions are fine though.  Anyone has the same problem?
Thanks very much
JenniferNery
If you are using this SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#GraphicsActions
                                <i:Interaction.Triggers>
                                    <i:EventTrigger EventName="Click">
                                        <esri:RedlineAction
                                    Color="#FF32FF00"
                                    DrawMode="Polygon"
                                    TargetName="MyMap"/>
                                    </i:EventTrigger>
                                </i:Interaction.Triggers>
Notice that the GraphicsLayer it uses is:
            <esri:GraphicsLayer ID="MyGraphicsLayer" Renderer="{StaticResource GraphicsLayerLineSymbol}" />
This Renderer is for Polyline geometry. The graphic is not removed, it is just not rendered because its geometry type cannot be given line symbol. You need to use a different Renderer with symbols that match the geometry type for graphics drawn by RedlineAction.
YingLin
Does that mean another graphics Layer have to be created for polygon rendering? The previous api example was able to accommadate both polyline and polygon on same graphic layer.
thanks
dotMorten_esri
Esri Notable Contributor
If you use one of the built-in renderers, the symbol type much match the geometry type, and thus all geometry types must be the same in the layer.
If you don't use a renderer, you can simply assign a symbol directly to each graphic that matches for the geometry type.
