Switching Esri:ArcGISTiledMapServiceLaye, Bing:TileLayer and esri:OpenStreetMapLayer
1301
03-14-2011 02:42 PM
FranciscoRodriguez1
Any body know how switching Esri, bing and OpenStreetMap in the same Map.Layers project? and show ever layer with only buttonradio cl¡c.
<esri:Map.Layers>
<esri:ArcGISTiledMapServiceLayer x:Name="TileMap" Url="http://maps.location-world.com/ArcGIS/rest/services/globalmapservice/MapServer" />
<Bing:TileLayer ID="BingLayer" LayerStyle="Road" Visible="False" ServerType="Production"
                   Token="Aoz7s-1dmOt1cit9hG7sPQcLz9O-MYXN4YRFIs8vph0NeHC_ya9goydUOtOpvZ9X"/>
<esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik"   Visible="False"/>
<esri:GraphicsLayer ID="MyGraphicsLayer"/>
</esri:Map.Layers>
Thank's for all.
JenniferNery
You can do something similar to this: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SwitchMap but instead of RadioButton.Tag contain the URL string, have it contain resource key.
XAML-code:
<Grid.Resources>
 <esri:ArcGISTiledMapServiceLayer x:Key="MyTiledLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
 <bing:TileLayer x:Key="MyBingLayer" LayerStyle="Road" Visible="True" ServerType="Production" Token="{StaticResource BingKeyString}" />
 <esri:OpenStreetMapLayer x:Key="MyOpenStreetMapLayer" Style="Mapnik" />
</Grid.Resources>
Code-behind:
private void RadioButton_Click(object sender, RoutedEventArgs e)
 MyMap.Layers.Clear();
 Layer layer = this.LayoutRoot.Resources[(sender as RadioButton).Tag] as Layer;
 MyMap.Layers.Add(layer);
FranciscoRodriguez1
Thank you, very much
FranciscoRodriguez1
Jennifer,
I writed:
Mimapa.Layers.Clear();
           Layer layer = this.LayoutRoot.Resources["MyBingLayer"] as Layer;
           Mimapa.Layers.Add(layer);
and only Show white screen. What is it the problem?
dotMorten_esri
Esri Notable Contributor
You could also just flip the Visible property on the two layers, and have them both added to the map up front. If you switch back and forth a lot, this would save you several layer iniitializations.
