Getting the visible layers
857
06-16-2010 01:22 PM
TomasDonda
Hello everyone. First of all excuse me if I do something wrong but´s the first time I ask something in a forum, i´m kinda newbie...
My problem is that I have a project with a ArcGISDynamicMapServiceLayer and this service turns on and off the layers according to the scale. I want to get a string of all the layers that are visible at a determined moment, for example, I´m looking at the map at an x scale, I click a button and I want to see the layers that are on at that moment.
Is this possible? So far I´ve tried with the following code but I get all the layers, not only the ones that are visible:
private void getListOfVisibleLayers()
            string visibLayers = "";
            StringBuilder sbVisibleLayers = new StringBuilder();
            sbVisibleLayers.Append("&layersVisib=");
ESRI.ArcGIS.Client.ArcGISDynamicMapServiceLayer serviceLayer =
(ArcGISDynamicMapServiceLayer)MyMap.Layers["PAE"];
            ESRI.ArcGIS.Client.LayerInfo[] layerInfoArray = serviceLayer.Layers;
            for (int index = 0; index < layerInfoArray.Length; index++)
                if (layerInfoArray[index].DefaultVisibility == true)
                    sbVisibleLayers.Append(layerInfoArray[index].Name);
                    sbVisibleLayers.Append(";");
            visibLayers = sbVisibleLayers.ToString();
If you have any idea that could help me it would be great, if not, never mind. Thanks for all!
DominiqueBroux
Esri Frequent Contributor
The scale info is available by the REST API  (e.g. http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/4?...) but is not available out of the box with the Silverlight API (performance issue). You have to request the rest end point by yourself.
jgalang posted a nice TOC sample (http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=168...) which displays the TOC in a tree view and respects the scale dependencies. I guess he did almost what you are trying to do.
TomasDonda
Thanks Dominique, all these things you showed me were really usefull. If someone else has this doubt, you´ll gotta know there´s no direct method. You´ll have to detect in which scale the user is (using the resolution) and from there see which layers are visible at that current range.
KND
