Using Bing Maps problem
1244
08-08-2010 11:09 PM
BrianBorg
I want to use bong maps in the api. I have followed the online example but I am getting this error
TileLayer' was not found because 'clr-namespace:ESRI.ArcGIS.Client.Bing;assembly=ESRI.ArcGIS.Client.Bing' is an unknown namespace.
The dll is referenced correctly and the application does compile.
AliMirzabeigi
Which version of Silverlight and ESRI API you're using?
BrianBorg
I am using v2.0
To solve the problem I had to add this line
ESRI.ArcGIS.Client.Geometry.MapPoint webmercatorP = ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(new ESRI.ArcGIS.Client.Geometry.MapPoint(0, 0));
But it doesn't make any sense. With this line the solution works fine
