Took Kit Navigations Full Extent centers on wrong spot
993
07-30-2010 09:30 AM
JohnPalmbach
I???m curious if anyone has had any success changing the ???Full Extent??? functionality of the ToolKit Navigation control.  I have already constrained the extent of my Silverlight Map to only the relevant area and zoom scales but now when I hit the full extent button it zooms out to a point that does not center on the right spot on the map.  Is there anyway I can override the extent that the button goes to?
I'm currently using the 1.2 API.  Is there possibly a easy solution to this in 2.0?
DominiqueBroux
Esri Frequent Contributor
One option is you to change the style of the navigation control by replacing the full extent button by your own button.
     - In blend, edit a copy of the navigation template
     - Find the 'ZoomFullExtent' button
     - Rename it
     - Add your own click handler
     - In the click handler, change the extent of the map as you want
JohnPalmbach
Thanks Dominique.  I'll give that a shot.
