GeometryService.BufferAsync doesn't accept decimal distance
1993
6
10-03-2011 10:30 AM
SteeveCouture
Hello,
I use the GeometryService.BufferAsync class to create a buffer.  It works great but I got a exception when my buffer distance have a decimal.
Ex.
Distance = 10 meter is correct
Distance = 10.6 meter is not correct ("I got 'distances' parameter is invalid")
Is it normal?  Because the BufferParameters.Distances is a list of double.
Steeve
JenniferNery
I cannot reproduce with SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#BufferPoint
I did not get a failure when I updated just this line:
bufferParams.Distances.Add(5.6);
SteeveCouture
If I try the same geometry service by the rest api, I got this message with a distance = 5.6 : 'distances' parameter is invalid
This is my request:
http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer/buffer?geometries=-108057...
Steeve
DominiqueBroux
Esri Frequent Contributor
What is your system decimal separator : comma or dot?
SteeveCouture
My decimal separator is comma.  I also changed my decimal separator (by regional setting) for dot but I got the same result.
Steeve
SteeveCouture
It's working if I change in Internet Explorer my language setting "fr-CA" by "en-CA":
Tools\Internet Options\Languages\
Do you have an idea how use distance with decimal with the Français (Canada) [fr-CA]?  Do we need to have the same language between the IE and the ArcGIS Server?
Steeve
P.S. See my attachments for more information.
DominiqueBroux
Hi Steeve,
It turns out that it's a server bug : "Input to operations in Geoprocessing Service and Geometry Service are not culture invariant "
This will be fixed in 10.0 SP3 (look at NIM070072 in the list of fixed bugs).
Thanks for your input.
