Geometry editing by using Editor
2063
01-10-2012 09:57 AM
weiliang
I try to use the Editor to edit my feature layer (already versioned), but when I run the website, all the Editor related button are greyed out. Is there any thing I did wrong? What I did is:
1) Add an Editor to the Grid resources:
<esri:Editor x:Key="EditWellPadPolygon" Map="{Binding ElementName=MyMap}"  LayerIDs="WetlandsDelinationArea"  GeometryServiceUrl="http://gis.ursbtr.com/ArcGIS/rest/services/Geometry/GeometryServer"  />
2) Add the Feature layer to the map layers:
<esri:FeatureLayer ID="WetlandsDelinationArea" ProxyUrl="../proxy.ashx"  Url="http://ourwebsite.com/ArcGIS/rest/services/Project/EcologyMobileProjects/FeatureServer/6"   AutoSave="True"  ValidateEdits="True" DisableClientCaching="True" Mode="OnDemand"  Opacity="0.8"  Visible="False" OutFields="*"  InitializationFailed="MapServices_InitializationFailed"/>
3) Add an editing panel with all the buttons:
                      <StackPanel x:Name="editSP" Orientation="Vertical" VerticalAlignment="Stretch" DataContext="{StaticResource EditWellPadPolygon}">
                        <Button Command="{Binding Add}" Content="1. Add New Record" ToolTipService.ToolTip="" Margin="14,0,14,5">
                            <Button.CommandParameter>
                                <sys:Int32>10101</sys:Int32>
                            </Button.CommandParameter>
                        </Button>
                        <Grid >
                            <Rectangle RadiusX="4" RadiusY="4" Margin="7,1,7,1" Stroke="Olive"></Rectangle>
                            <StackPanel Orientation="Vertical" VerticalAlignment="Stretch">
                                <Button Command="{Binding Select}" CommandParameter="New" Content="2. Select a Record to Delete" Margin="14,8,14,8"/>
                                <Button Command="{Binding ClearSelection}" Content="Clear Selection"  Margin="28,2,14,8" Visibility="Collapsed"/>
                                <Button Command="{Binding DeleteSelected}" Content="Delete Selected Record" Margin="28,2,14,8" Visibility="Collapsed"/>
                            </StackPanel>
                        </Grid>
                        <Button Command="{Binding EditVertices}" Content="3. Change a Record Shape" Margin="14,5,14,5"/>
                    </StackPanel>
Wei
ChristopherHill
As far as I can tell everything looks fine, only thing you didn't provide is the map tag so that I confirm you named your map correctly.  <esriMap x:Name="MyMap" >. Is editing allowed on the service? Could you paste the entire mainpage.xaml.
weiliang
Thanks for your reply, Christopher. I found the problem it that I set the feature layer, which should be visible, as invisible.
Wei
ChristopherHill
Yes, didn't see that. It will detect only visible layers.
Jitendrudulacaraju
In the ADD binding, do you set the command property to 'Editor.ADD' ? I want some reference code for adding a new feature in the feature class.
                        </Button>
                        <Grid >
                            </StackPanel>
                        </Grid>
                    </StackPanel>
Wei
JenniferNery
