Forming a field of type geometry in Geodatabase
3272
12-06-2013 12:06 AM
by Anonymous User
Not applicable
Original User: aviabunin
Dear Gurus !
There is a table events with fields X, Y - containing the coordinates of points, which must be registered in the geodatabase. Created geodatabase cuks_gdb with standard tools of arcgis desktop 10.1. Table events copied in geodatabase :
select * into cuks_gdb.sde.events from cuks.dbo.events
3 . In the cloned table added field "shp" type geometry.
4 . Formed a field value by field values �??�??x, y:
update cuks_gdb.sde.events set Shp = geometry :: STGeomFromText ('Point (' + ltrim (STR (x, 99, 11 )) + '' + ltrim (STR (y, 99, 11) ) + ')' , 28406 );
All formed ,  error messages were not. But when I try to save changes in any field then I get an error message
The parameter type cuks_gdb.sys.geometry is invalid. Parameter name: value
How to fix ?
by Anonymous User
Not applicable
Any ideas?
1. Is there are any tool to form geometry field from x,y - fields?
2. Is there are any other way to form needed table in geodatabase from x,y-table in sql server?
3. The initial problem is , that service on the table with ObjectID and Shape fields not worked  - data not saved in the example with EditorWidget. Only delete operation work well, and normally executes update operation , when I test feature service in arcgis,com.
4. Can I update and add features in geodatabase from arcgis desktop 10.1 and how I can do this?
Thanks in advance!
AnatoliiTerentiev
by Anonymous User
Not applicable
Original User: dbroux
That doesn't seem to be a Silverlight question.
Concerning ArcGIS server you can look at Make XY event layer tool. But it's more likely a Microsoft SQL question.
