Feature Data Grid
1509
09-15-2011 12:18 PM
JerryBiedenbender
Hello,
   I'm trying to incorporate the feature data grid into my application and the one in the samples seems to be very buggy when I use it. Does anyone have some cleaned up code for a feature data grid?
Jerry
GarimaVyas
Jerry,
I am not sure what exactly are you looking for. Implementation of FeatureDataGrid is as simple as dropping the tag and binding the map and graphics/feature layer. If you could explain what is buggy or what you are trying to implement, we might be able to address specific questions.
JerryBiedenbender
I am using this code...
<esri:FeatureDataGrid Grid.Row="2" x:Name="MyDataGrid"
    Map="{Binding ElementName=MyMap}"
    GraphicsLayer="{Binding ElementName=MyMap, Path=Layers.[Dispatch]}" />
Regardless of how I have it sized it takes up half of the screen and every time I open the map it doubles my assets. Also after starting the web map a few times I had thousands of assets in my dispatch layer, It doubles my layer each startup.
Jerry
GarimaVyas
Jerry,
The size should follow the row definition size you specified for the grid's third row. I am assuming that it is not set to "*". However, I will be interested in finding out if it doesn't.
Secondly, the FeatureDataGrid has no control over adding/removing features, unless you are adding the feature layer in one of the event handlers involved. Please check where and how the dispatch layer is added to the map.
JerryBiedenbender
I resolved the problem thanks, I only had two grids, I added a third one and set that sizes correctly.
Thanks for your help,
Jerry
