ESRI Map not displaying from https
733
07-28-2010 01:10 PM
JohnHarvey
I have started working on a Silverlight application that is being hosted on an https:// site. I have put a crossdomain.xml file on the server and configured as follows, but it will not display the map. I can see the map from my local workstation when debugging the app. I see this message has been posted before, but the last statement I have seen said it wasn't available last August (2009), but should be within a few months. It is now almost Aug (2010)
Here is the mappage link: https://kiosk.memphispolice.org/sl/SilverlightApplication4TestPage.html
Here is the content of the crossdomain.xml file:
  <?xml version="1.0" encoding="utf-8" ?>
- <access-policy>
- <cross-domain-access>
- <policy>
- <allow-from http-request-headers="*">
  <domain uri="*" />
  <domain uri="http://*" />
  </allow-from>
- <grant-to>
  <resource path="/" include-subpaths="true" />
  </grant-to>
  </policy>
  </cross-domain-access>
  </access-policy>
DominiqueBroux
Esri Frequent Contributor
Did you see this article Using service across scheme ?
As far as I know, it's still valid. That means that if your application is hosted on an https server, you can't access image hosted on an http server.
