Esri Legend - dynamically adding layers during runtime
2736
06-19-2012 03:42 PM
EdwardSon
I have Esri Legend control which is bound during initialization to the Map.Layers, everything shows fine, including GroupLayers.
But during runtime, when I add new GraphicsLayers as result of searches, and I add these to the Current.Map.Layers from code behind, the Legend control doesn't seem to get updated.
I am adding layers from an asynchronous code thread, btw...
JenniferNery
Is Legend.LayerIDs property set? If yes, this needs to include the new layer ID's. If not, does your new GraphicsLayer have a renderer?
You can try the following code:
 <Grid x:Name="LayoutRoot">
  <esri:Map x:Name="MyMap" WrapAround="True">
   <esri:ArcGISTiledMapServiceLayer
                Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer" />
  </esri:Map>
  <esri:Legend Map="{Binding ElementName=MyMap}"
                         LayerItemsMode="Tree"
       VerticalAlignment="Top" HorizontalAlignment="Right" />
  <Button VerticalAlignment="Top" HorizontalAlignment="Left" Content="Add Layer" Click="Button_Click"/>
 </Grid>
  private void Button_Click(object sender, RoutedEventArgs e)
   var l = new GraphicsLayer() { ID = "MyLayer" };
   l.Renderer = new SimpleRenderer()
    Symbol = new SimpleMarkerSymbol()
     Color = new SolidColorBrush(Colors.Blue),
     Size = 20d,
     Style = SimpleMarkerSymbol.SimpleMarkerStyle.Square
    Label = "Locations"
   l.Graphics.Add(new Graphic() { Geometry = new MapPoint(-140.9, 63.391, new SpatialReference(4326)) });
   MyMap.Layers.Add(l);
