Generate KML/KMZ support operation-  rest end point
2135
06-18-2012 02:05 PM
DavidAshton
I was playing around with generating a KML/KMZ file. I started with a Geoprocessing task and got that up and going with my silverlight app but instead of having to utilize a gp services I was wondering if there was a way just to send the parameters directly to the rest endpoint and take advantage of the supported operation "Generate KML"
for example -
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/LandusePlanning/M...
Has anyone done this?  It is possible right?  Do you have any knowledge or code you could share?
David
JenniferNery
We have not exposed this from ArcGIS API for Silverlight. You could use the following documentation as resource: http://sampleserver3.arcgisonline.com/ArcGIS/SDK/REST/generatekml.html
