ESRI.ArcGIS.Client.Geometry. Geodesic.Area problem
1348
09-25-2012 02:36 AM
__8
  I am using ESRI.ArcGIS.Client.Geometry. Geodesic.Area method ,when the parameter Polygon has more than one rings,the method throw an exception " Index was out of range - Must be non-negative and less than the size of the collection. Parameter name: index".
How can I???calculate the area of polygon with serveral rings?
thanks
DominiqueBroux
Esri Frequent Contributor
I am unable to reproduce that issue. Could you share a repro case or give more info on how to reproduce the issue?
Thanks
__8
Thanks
Hi,there is a txt which contains the mappoint coordinates of the polygon with rings ,you can parse the txt and covert it to a polygon.
thanks
__8
Thanks
Hello? any progress?
DominiqueBroux
We have reproduced the issue that should be fixed in the next version.
At this time, the workaround might be to create one polygon by ring and to sum the area by yourself.
Thanks for reporting that.
