Adding new feature using coordinates
1166
10-03-2012 12:25 AM
AhmedDD
Hi all
How can I create a new polygon feature using coordinates, The goal is to allow an end user to enter the coordinates of the polygon and then create the feature and save into a SDE SQLServer DB, is it possible?
any help will be greatly appreciated
Regards
DominiqueBroux
Esri Frequent Contributor
You can create new features by code. there is a sample here : http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#AddGraphics
To store them in the GDB, you need to set up a feature server and allow editing for this server. But there is nothing specific because the user enters the coordinates manually.
There are editing samples here : http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#EditToolsAutoSave
DominiqueBroux
AhmedDD
Thanks Dominique, that was helpful
