Custom code behind Fill Symbol
1657
03-10-2011 10:04 AM
FranciscoRodriguez1
I have this code line:
void AddPolygonGraphicsReport(string Coodinates)
            GraphicsLayer PolygonGraphicsLayer = Mimapa.Layers["MyGraphicsLayer"] as GraphicsLayer;
            PointCollectionConverter pointConverter = new PointCollectionConverter();
            FillSymbol iFillSymbol = new FillSymbol
                BorderBrush = new SolidColorBrush(Color.FromArgb(0, 255, 0, 0)),
                BorderThickness = 2,
                Fill = new SolidColorBrush(Color.FromArgb(0, 255, 0, 0))
            ESRI.ArcGIS.Client.Geometry.PointCollection PointCollectionReport =
            pointConverter.ConvertFromString(Coodinates) as ESRI.ArcGIS.Client.Geometry.PointCollection;
            ESRI.ArcGIS.Client.Geometry.Polygon PolygonReport = new ESRI.ArcGIS.Client.Geometry.Polygon();
            PolygonReport.Rings.Add(PointCollectionReport);
            Graphic GraphicPolygon = new Graphic()
                Geometry = PolygonReport,
                Symbol = iFillSymbol
                  PolygonGraphicsLayer.Graphics.Add(GraphicPolygon);
But Silverlight can't show the type BorderBrush, BorderThickness and fill. Only obtain proporeties when write xaml:
<esri:SimpleLineSymbol x:Key="DefaultLineSymbol" Color="Green" Style="DashDot" Width="4" />
A same problem with SimpleLine:
SimpleLineSymbol iSimpleLineSymbol = new SimpleLineSymbol
                Width = size,
                Color = new SolidColorBrush(SLGeoviewerClassLibrary.Model.Common.ArrayToColor(color)),
                Style = SLGeoviewerClassLibrary.Model.Common.sSimpleLineStyle(Convert.ToByte(style))
            GraphicsLayer LineStringsGraphicsLayer = Mimapa.Layers["MyGraphicsLayer"] as GraphicsLayer;
            List<ESRI.ArcGIS.Client.Geometry.Polyline> polylineList = new List<ESRI.ArcGIS.Client.Geometry.Polyline>();
            ESRI.ArcGIS.Client.Geometry.PointCollection pointCollection = new ESRI.ArcGIS.Client.Geometry.PointCollection();
            for (int i = 1; i < lsc.Length; i++)
                string[] Coords = null;
                Coords = lsc.Split(' ');
                pointCollection.Add(new MapPoint(Convert.ToDouble(Coords[1], System.Globalization.CultureInfo.InvariantCulture),
                                                 Convert.ToDouble(Coords[2], System.Globalization.CultureInfo.InvariantCulture)));
            ESRI.ArcGIS.Client.Geometry.Polyline polyline = new ESRI.ArcGIS.Client.Geometry.Polyline();
            polyline.Paths.Add(pointCollection);
            Graphic GraphicLineStrings = new Graphic();
            GraphicLineStrings.Geometry = polyline;
            GraphicLineStrings.Symbol = LayoutRoot.Resources["DefaultLineSymbol"] as Symbol;
            LineStringsGraphicsLayer.Graphics.Add(GraphicLineStrings);
Please help me.
Thanks
JenniferNery
The following SimpleFillSymbols are equivalent:
XAML-code:
<esri:SimpleFillSymbol x:Key="RedFillSymbol" Fill="#66FF0000" BorderBrush="Red" BorderThickness="2" />
Code-behind:
SimpleFillSymbol redFillSymbol= new SimpleFillSymbol()
Fill = new SolidColorBrush(Color.FromArgb(102, 255, 0, 0)),
BorderBrush = new SolidColorBrush(Colors.Red),
BorderThickness = 2d
You can use either one to apply symbol on the polygon:
private void AddPolygon()
 GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
 Polygon polygon = new Polygon();
 PointCollection pts = new PointCollection();
 pts.Add(new MapPoint(110.039, -20.303));
 pts.Add(new MapPoint(132.539, -7.0137));
 pts.Add(new MapPoint(153.281, -13.923));
 pts.Add(new MapPoint(162.773, -35.174));
 pts.Add(new MapPoint(133.594, -43.180));
 pts.Add(new MapPoint(111.797, -36.032));
 polygon.Rings.Add(pts);
 Graphic graphic = new Graphic()
  Geometry = polygon,
  Symbol = redFillSymbol // or LayoutRoot.Resources["RedFillSymbol"] as Symbol
 graphicsLayer.Graphics.Add(graphic);
Are you saying defining symbol in code-behind does not work?
FranciscoRodriguez1
Yes Jennifer,
I can't show  properties define on code behind of polygon and Line symbol. When define in XAML work's fine but don't  work when I define by code behind.
Work
Don't Work
What can I do?
Friends
FranciscoRodriguez1
Dear Jennifer,
Thank i found the problem, I have function don't work fine:
public static double StringToDouble(string sText)
            try
                string sdecSep = (0.1).ToString().Substring(1, 1);
                return Convert.ToDouble(sText.Replace(".", ",").Replace(",", sdecSep));
            catch (Exception)
                return 0;
public static Color ArrayToColor(string[] Col)
            try
                return Color.FromArgb(
                    Convert.ToByte(Convert.ToInt32(Math.Round(StringToDouble(Col[0].ToString()) * 255, 0))),
                    Convert.ToByte(Col[1].ToString()),
                    Convert.ToByte(Col[2].ToString()),
                    Convert.ToByte(Col[3].ToString()));
            catch (Exception)
                return Color.FromArgb(255, 0, 0, 0);
Thank's a lot
JenniferNery
You can look at one of the marked answer in this SL forum: http://forums.silverlight.net/forums/p/144015/321286.aspx
I think this is the correct conversion from hexadecimal string to color.
