Creating a hyperlink result from query function.
1878
8
05-15-2012 08:01 AM
JaredWhite
I'm needing to write a function where my app not only brings up query results, but also pulls a hyperlink from my map (the data tables on my map service have web addresses under the Path "path"). I used the identify query function (http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Identify) from the api samples. How would I set it up so that the hyperlink also recieves the info from the map.
Xaml would be something like this
    <Grid>
    <TextBlock Text="Query Results" />
    <Grid x:Name="IdentifyResultsPanel"
        <ComboBox x:Name="IdentifyComboBox" SelectionChanged="cb_SelectionChanged" />
        <HyperlinkButton x:Name="HyperlinkButton" />
        <ScrollViewer VerticalScrollBarVisibility="Auto" >
            <slData:DataGrid x:Name="IdentifyDetailsDataGrid" >
                <slData:DataGrid.Columns>
                    <slData:DataGridTextColumn Binding="{Binding Path=Key}" />
                    <slData:DataGridTextColumn Binding="{Binding Path=Value}"/>
                </slData:DataGrid.Columns>
            </slData:DataGrid>
        </ScrollViewer>
    </Grid>
Code Behind
        #region Query Results
        private void QueryPoint_MouseClick(object sender, ESRI.ArcGIS.Client.Map.MouseEventArgs e)
            ESRI.ArcGIS.Client.Geometry.MapPoint clickPoint = e.MapPoint;
            ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
                Geometry = clickPoint,
                MapExtent = TabletMap.Extent,
                Width = (int)TabletMap.ActualWidth,
                Height = (int)TabletMap.ActualHeight,
                LayerOption = LayerOption.visible,
                SpatialReference = TabletMap.SpatialReference
            IdentifyTask identifyTask = new IdentifyTask("http://XXXXXXXXXXXXXXXXXXX");
            identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
            identifyTask.Failed += IdentifyTask_Failed;
            identifyTask.ExecuteAsync(identifyParams);
            GraphicsLayer graphicsLayer = TabletMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
                Symbol = LayoutRoot.Resources["DefaultPictureSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol
            graphicsLayer.Graphics.Add(graphic);
        public void ShowFeatures(List<IdentifyResult> results)
            _dataItems = new List<DataItem>();
            if (results != null && results.Count > 0)
                IdentifyComboBox.Items.Clear();
                foreach (IdentifyResult result in results)
                    Graphic feature = result.Feature;
                    string title = result.Value.ToString() + " (" + result.LayerName + ")";
                    _dataItems.Add(new DataItem()
                        Title = title,
                        Data = feature.Attributes
                    IdentifyComboBox.Items.Add(title);
                IdentifyComboBox.SelectedIndex = 0;
            QueryPanel.IsExpanded = true;
        void cb_SelectionChanged(object sender, SelectionChangedEventArgs e)
            int index = IdentifyComboBox.SelectedIndex;
            if (index > -1)
                IdentifyDetailsDataGrid.ItemsSource = _dataItems[index].Data;
        private void IdentifyTask_ExecuteCompleted(object sender, IdentifyEventArgs args)
            IdentifyDetailsDataGrid.ItemsSource = null;
            if (args.IdentifyResults != null && args.IdentifyResults.Count > 0)
                IdentifyResultsPanel.Visibility = Visibility.Visible;
                ShowFeatures(args.IdentifyResults);
            else
                IdentifyComboBox.UpdateLayout();
                IdentifyResultsPanel.Visibility = Visibility.Collapsed;
        public class DataItem
            public string Title { get; set; }
            public IDictionary<string, object> Data { get; set; }
        void IdentifyTask_Failed(object sender, TaskFailedEventArgs e)
            MessageBox.Show("Identify failed. Error: " + e.Error);
        #endregion
Any help would be great, thanks.
DominiqueBroux
Esri Frequent Contributor
JaredWhite
Thank you very much, this gives me some badly needed base functionality till I can figure out how to do this properly. I'd still like to use a dedicated hyperlink button though. If you don't have time, tend to people with more pressing problems, but if you don't mind, how would i go about populating a hyperlink button with a particular field of data pulled from an identify query like what i have written?
Thanks in advance.
JaredWhite
Solved. You create a loading row that filters out everything but strings that contain "http", then pipe that value too your button containing a new page command. Thanks for the guidance.
        public string URLlink { get; set; }
        private void IdentifyDetailsDataGrid_LoadingRow(object sender, DataGridRowEventArgs e)
            string value = e.Row.DataContext.ToString();
            if (value.Contains("http"))
                //Hides URLLink data line from Datagrid Results
                SolidColorBrush brush = new SolidColorBrush(Colors.Transparent);
                e.Row.Foreground = brush;
            else
            try
                string s = e.Row.DataContext.ToString();
                if (s.Contains("http"))
                    string[] sSplit = s.Split(',');
                    string[] link = sSplit[1].Split(']');
                    URLlink = link[0];
                else
            catch
        private void DTSButton_Click(object sender, RoutedEventArgs e)
            HtmlPage.Window.Navigate(new Uri(URLlink), "_blank");
                            <Button x:Name="DTSButton" Click="DTSButton_Click"/>
 <slData:DataGrid x:Name="IdentifyDetailsDataGrid" AutoGenerateColumns="False" HeadersVisibility="None"
                              Background="White" LoadingRow="IdentifyDetailsDataGrid_LoadingRow">
                                        <slData:DataGridTextColumn Binding="{Binding Key}" FontWeight="Bold"/>
                                        <slData:DataGridTextColumn Binding="{Binding Value}" />
                                </slData:DataGrid>
TanyaOwens
I get an error "The name 'HtmlPage' does not exist in the current context". What am I missing?
JenniferNery
I think you just need to add reference to this .NET Assembly "System.Windows.Browser" and resolve reference to add using statement for this namespace http://msdn.microsoft.com/en-us/library/system.windows.browser.htmlpage%28v=vs.95%29.aspx
TanyaOwens
I got it to work but it oddly took out my field that contained the website from the datagrid. Really I was just looking for other hyperlink methods to try to resolve my issue from my post http://forums.arcgis.com/threads/58727-Field-Hyperlink. If you could provide some assistance on my field hyperlink post I would greatly appreciate it. Right now I am just lost on what to do to get my identify layer selection in three datagrids to each have a hyperlink.
Thanks for your help.
JaredWhite
I wrote it that way.  Just change it to this
            try
                    URLlink = link[0];
                else
            catch
TanyaOwens
Thanks! That brought the fields back into the datagrid. Have you had any luck with getting a hyperlink to work for three separate data grids. Its seems like it should be a simple task but I just can't seem to work it out. See my original post for more info. http://forums.arcgis.com/threads/58727-Field-Hyperlink
